Ultimaker 2 and Ultimaker 2+ firmware was the issue.
When connected to the PC in charge of the printings, the PC recognised as the plus model, updating the drivers to the wrong ones, and making the motor work in opposite direction.
PC used was a Windows 7 with Cura
Edited as SOLVED and thanks for the fast response with the possible issues.
Edited by Guest-
2
SandervG 1,519
Thank you for your post.
Do you have an Ultimaker 2, or Ultimaker 2+?
Because the Ultimaker 2+ has a geared feeder to make it stronger, it also means the extrusion direction is actually in reverse. Because of the gear.
My feeling is you are either printing Ultimaker 2-files, or have installed Ultimaker 2 firmware.
Have you installed new firmware?
Are you slicing in Cura?
Make sure to add your machine, double check if it is the regular or '+' and try again
Looking forward hearing from you how it goes!
setroson 2
A normal Ultimaker2, and no firmware change has been made yet. Not even looked into it. As stated, is been tested for less than 1 day; Printer is new.
- First impression was smooth and ok. The robot from the SD card that Ultimaker2 brings along with the Printer.
- Second was wrong, but we blamed our design as part of the problem.
- Thirdly we tried the robot again, to try to locate our error, but error seems to be in configuration somehow and problem remains.
P.S.: I'm completing the profile
