It is red and brown, thank you.
I have checked and double checked the the sensor/heater and have ensured that the fan shroud is not touching the block or nozzle.
The error appears as soon as you switch on the machine now.
I will install the new sensor as soon as it arrives and let you know how I get on.
Thanks again
IRobertI 513
Is it red and brown? If so, you can ignore it, it should be left unconnected.
As for the error. Make sure your temperature sensor and heater is fully inserted and held firmly in place. Also check that the block or nozzle does not touch any part of the fan shroud.
