I have the 1.5.6 board with 50amp mosfets. The mosfet is STP55NF06L which I ordered from Mouser for $1.40.
Meanwhile, I snagged the mosfet from heater 2 since I currently only use single extrusion, and, even after commanding the heated build platform off it is stuck on. I reset everything, and still on.
Any ideas?
Daid 304
Which electronics version did you have? Older electronics had 5Amp mosfets, newer have 50Amps mosfets. You should be able to get the part number from:
http://reprap.org/wiki/Ultimaker%27s_v1.5.6_PCB
