a higher infill will be better, it is not very hard to remove, there is a gap between the model and the infill. Only the top will 'fall' on the infill and leave little scars after removal.
When the print starts to bridge over the infill you can slow the speed down manually, and when it's done return to normal speed.
It is a small print, so maybe check your cooling settings, the fan should be on full when the bridging starts.
Okay, thank you very much for your help!
Did your next print come out better?
SandervG 1,512
Hi Adam,
Welcome to the forum!
It would be very helpful, especially in a case like this, if you could add some photo's of your print which illustrates the problem.
That is usually very helpful for everyone to understand the issue.
Looking forward seeing the pictures
