Sounds like a hardware issue. There could be an electrical problem with the wires or the encoder.
I have seen this issue on one machine where a thin strand of filament ended up inside the knob housing between the knob and the housing preventing the button from being pushed far enough to register. There is a small hole in the housing inside the printer where you can push to remove the knob and clean out the housing.
nallath 1,080
I've never heard of any g-code messing with your front panel (or octo print messing it up either). As there are multiple people that have succesfully printed this way, i'm pretty sure it's not a software thing.
