Here's that link again - fixed I hope:
Do you have a volt meter? You want to measure the voltage coming into the UM2.
Did you try powering off the brick for an hour or longer? That brick has a computer in it and it can get in a bad state but it takes hours or days to reboot it because the brick holds so much power for so long.
To make things clearer - even if your printer is off for an hour the brick is still plugged in and powerd up. You need to unplug it for a VERY long time for it to reboot.
I'll show you which pins to measure after dinner...
gr5 1,872
Sounds like your 24V is bad. Try unplugging the power supply for an hour - it really takes that long (sometimes a few days!) for it to completely power down - you can tell because that little blue led stays on for a long time. Then plug it all back together and see if your LED's are brighter.
it's also possible that your eeprom settings are messed up - in there it sets the scale factor for you filament chosen and your led brightness. You can do a "reset to factory settings" and it will reset all those values but you will also lose your "odometer" reading so you might want to check how many hours you ahve printed first and write that down.
I don't think it's eeprom settings though - you can check under your filament settings to see what the fan multiplier is - for PLA it should be 100%.
You can get the board layout and schematic of the UM2 here - I would check the voltage going in and out of K1. K1 may be defective and lowering the voltage when the heated bed is on.
If 24V is good your heated bed should get from 20C to 60C in about 2 minutes. So you can test that also - if it takes say 10 minutes then it's not 24V. It's something less.
It's much more likely your power brick is bad than anything on the white board, but again, K1 is the first place to check.
ULTIMAKER 2 SCHEMATIC - click "raw":
https://github.com/Ultimaker/Ultimaker2/blob/master/1091_Main_board_v2.1.1_%28x1%29/Main%20Board%20V2.1.1.pdf
UltiKid 2
Well actually, my heated bed has started to take longer to heat too. More like 10 minutes than 2. So how can I check the K1?
