yellowshark 153
Couple of points, you did not met ion what temp you used for the atomic pull but I assume you did not/have not got all the ABS out - I saw some under-extrusion on one of the photos.
Also in the earlier posts I read them as being that you felt that the bed levelling was causing your print head to hit the print - to quote you "From what I have noticed, the probability to get bad prints with PLA increases the more narrow the nozzle is to the print bed. It touches overhanging material and rips the printed structures apart."
This has nothing to do with bed levelling - the distance you refer to is the layer height.
Top Posters In This Topic
21
20
5
5
Popular Days
Mar 8
8
Mar 18
7
Mar 15
6
Mar 4
6
gr5 21 posts
asb 20 posts
peggyb 5 posts
ultiarjan 5 posts
Popular Days
Mar 8 2016
Mar 18 2016
Mar 15 2016
Mar 4 2016
Posted Images
neotko 1,417
There's also something Innoted after reading all the posts and answers. You mention you used the atomic method
What I don't see you mention it's if you did it properly. Because it isn't something you just do 'once'. It's something you need to do and redo and do again ultil you get a perfectly clear atomic pull. If not, particles of the other filament pla on abs or abs on pla, will stuck ans clog the nozzle. Also, that drips of many prints looks to me preassure changes on the filament extrusion.
You need to think of it as an a pump system. If you get particles on the way of the filament, preassure changes and becomes unstable, so the filament speed deposition changes and makes errors. There are many many factors when printing and the learning curve it's there. As gr5 says any good printer as wasted a good amount of filament just to control the parameters of a brand (not just a kind of plastic). It takes time, experience and aoftware controlto avoid errors and it isn't something that can be done just by doing it, you need to control all the parameters to get consistency and repeatability.
So first thing first.
Do 20 atomics. But before that, get a new nozzle. That one its curved and will never give good prints.
