Is it because the cooling fan?
swq0603
Posted (edited) · Is it because the cooling fan?
   These days I found that the surface of my model is not smooth, looks like the over-extrusion But I have checked the amount of the meterial from the nozzle, it is fine. I suspect it is because the cooling fan for I replaced the fan days ago . Maybe the fan speed cannot meet the reqirement.  Thanks a lot! BTW, I am using the following parameter:
layer height:0.1mm
temp:210
speed:90
PLA
Another pic:(temp:220)
    Posted · Is it because the cooling fan?
    It indeed looks like a cooling problem since the problem is the worst at the overhang. Altough there are a couple of things that could also cause these crappy kind of prints. I would try to clean your nozzle and level your bed just to make sure before you start ordering new fans
    Is it also related to the dirty nozzle or bed leveling?
    I'd say you can print at a lower temperature also. This leaves the material cooler to start with.
    Possibly when you go lower you might also need to go a little slower
    Yes, I tried lower the temperature to 200 with a lower speed. But the effect is not very satisfied. I also tried lower the flow, which cannot solve this issue either and introduce the under extrusion. My understanding is that the following parameter can print most models:
    Later height 0.1mm
    Temp:210
    Speed:90
    Flow 100%
    But now it cannot work for me.
    Can you feel the air flow from the fan? Is it strong? Are the blades dusty?
    What if you slow down to 40 mm/sec and 200?
        • 10 replies
