hi Daid,
thanks for the reply,
especially thanks for the warning about doing it while the hotend was hot, I would have broken it otherwise.
you were right, I tightened it from both sides (nozzle & brass), and it's working fine now.
of course, I had to re-align the z-axis after I tightened the nozzle. (just mentioning it for anybody who would have the same problem)
Daid 301
The hotend is leaking, could be a gap between the nozzle and the brass part. Make sure the nozzle is screwed in tightly. As well as the brass being screwed in tightly. Your hotend needs to be hot to do this, as it will break otherwise.
If this doesn't work you could put in some teflon plummer tape on the treads to seal it. Shouldn't be needed with your V2 hotend, but it sealed up V1 hotends quite good.
