kenjo 3 Posted March 4, 2016 in Simplify3D vs Cura Is the result they get in this video a one off thing or is simplify3d generally this much better ? Share this post Link to post Share on other sites
Nicolinux 250 Posted March 4, 2016 in Simplify3D vs Cura Looking at the vide I'd say the default speed setting in Cura was way too high for that model. The head moves very fast so I assume Simplify3D just prints way slower... Share this post Link to post Share on other sites
neotko 1,355 Posted March 5, 2016 in Simplify3D vs Cura (edited) Wow that's the most stupid video about slicers ever... S3D it's better than cura in many aspects BUT that video test it's so wrong. Also S3D default profile it's really really horrible. And yes s3d it's much better than old cura but not muuch better than the new cura. Worse slicer comparison video ever! Edited March 5, 2016 by Guest Share this post Link to post Share on other sites
yellowshark 123 Posted March 5, 2016 in Simplify3D vs Cura Yes I thought the Cura print speed was faster, which on that size of model makes the comparison sort of pointless. One might argue that it is a comparison of default settings and on that video one might say that S3D has a better default profile - unless of course you are printing a model that takes up the entire print bed!! I can spend hundreds of pounds on an Adobe product but the guys give you a 30 day trial version unlike these guys who expect me to shell out 150usd on no evidene at all. Share this post Link to post Share on other sites
eldrick 54 Posted March 6, 2016 in Simplify3D vs Cura One consideration is that S3D is copy-protected, and as a result, if your system configuration changes at all, even system updates, you will be forced to re-install it over and over again, including re-entering a long passcode. I found this so offensive and annoying that I tossed S3D. Share this post Link to post Share on other sites
ultiarjan 1,076 Posted March 6, 2016 in Simplify3D vs Cura One consideration is that S3D is copy-protected, and as a result, if your system configuration changes at all, even system updates, you will be forced to re-install it over and over again, including re-entering a long passcode. I found this so offensive and annoying that I tossed S3D. Never had this with system updates. The only time I had to reenter the passcode was after a complete windows re-install. Share this post Link to post Share on other sites
nallath 534 Posted March 7, 2016 in Simplify3D vs Cura The guy also has cura in one at a time mode for some weird ass reason. We just have a different definition for "normal" (as I'd guess that s3d takes about 2 times as long, which makes it a rather unfair comparison) Share this post Link to post Share on other sites
yellowshark 123 Posted March 7, 2016 in Simplify3D vs Cura Lol @nallath, if I do multiple printing I nearly always use "print one at a time", as you say we all have different normals My view is that if I am printing say 5 or 6 copies and the print fails 75% of the way through, I will actually have 3 or 4 completed models. Also it stops the print head flying between the models and possibly leaving artefacts where it leaves one model and joins another. Equally I have printed "all at one time" with success. Just a matter of risk management really. Share this post Link to post Share on other sites
nallath 534 Posted March 7, 2016 in Simplify3D vs Cura I meant that printing a single model with one at a time doesn't change anything (and isn't a default setting if I recall correctly). Share this post Link to post Share on other sites
ultiarjan 1,076 Posted March 7, 2016 in Simplify3D vs Cura All-at-once is indeed the default. I do think the ease of use of one-at-a-time in Cura, is a big advantage over S3D. Share this post Link to post Share on other sites
DidierKlein 638 Posted March 7, 2016 in Simplify3D vs Cura i don't understand is there something different when you print one model in one at time or all at once? But i agree S3D is nice but this is not a good comparison, what is S3D high quality profile? is it even 0.1mm layers ? And what about the speed settings we don't see... Share this post Link to post Share on other sites
Nicolinux 250 Posted March 7, 2016 in Simplify3D vs Cura UPDATE They responded to my question on the comparison (on Youtube). Here is the answer: Hi Sorin, the overall print speed for Simplify3D changes throughout the print. Simplify3D designates different print speeds for different areas of the model (e.g First layer, Infill, Outline etc). We used the preset High quality setting and only changed the infill amount to match Cura at 20%. The Simplify3D print took around 4 minutes longer to print. Hope that helps. Share this post Link to post Share on other sites
neotko 1,355 Posted March 7, 2016 in Simplify3D vs Cura Well S3D has options to underspeed the layers if they are close to X seconds. True. But again, the default print speed of the um2 profile it's quite low. A good test would be to copy the speeds from one to the other. I think it's a bad test, but also I agree that s3d it's better than cura. Share this post Link to post Share on other sites
Nicolinux 250 Posted March 7, 2016 in Simplify3D vs Cura It depends on the Cura version. In my Cura (15.04.4) the shell thickness for the "high quality" setting is set to 0.9!! And infill speed is still at 80mm/s which is way too high if you print at the default temp of 210° Share this post Link to post Share on other sites
DidierKlein 638 Posted March 7, 2016 in Simplify3D vs Cura Cura also slows down with the min layer time setting. It's default value is also 5sec Share this post Link to post Share on other sites
neotko 1,355 Posted March 7, 2016 in Simplify3D vs Cura Cura also slows down with the min layer time setting. It's default value is also 5sec Yes but S3D does a Speed slow down, for each layer. It's a progressive aproach. Cura stops to make a min layer time, S3D slows down the print speed for each layer to reach the time (more or less). Basically, it adjust each layer speed. I never use this XD but it's there. Share this post Link to post Share on other sites
yellowshark 123 Posted March 8, 2016 in Simplify3D vs Cura Surely not. I rarely print anything these days with a layer time below 10 secs but I am sure Cura slows down (or used to slow down) in the way you describe for S3D (????). Maybe I am confusing it with slic3r which I used to use a long time ago. Share this post Link to post Share on other sites
yellowshark 123 Posted March 8, 2016 in Simplify3D vs Cura i don't understand is there something different when you print one model in one at time or all at once? But i agree S3D is nice but this is not a good comparison, what is S3D high quality profile? is it even 0.1mm layers ? And what about the speed settings we don't see... I do not think so - Nallath's post confused me too. You have to have one set and I never check that parameter unless I am printing multiple models Share this post Link to post Share on other sites
nallath 534 Posted March 8, 2016 in Simplify3D vs Cura There is no difference with respect to settings, but my point was that they are clearly not using the default profile, as the default has print sequence to all at once. Share this post Link to post Share on other sites
yellowshark 123 Posted March 8, 2016 in Simplify3D vs Cura Ah, cunning, well spotted Share this post Link to post Share on other sites
nallath 534 Posted March 8, 2016 in Simplify3D vs Cura Ah, cunning, well spotted When you look at Cura for 8 hours a day, you tend to notice those things 3 Share this post Link to post Share on other sites
