Good point. I can see when turning the control wheel that it is off centre and wonky, Definitely the spindle. Need to get hold of a new one. I'll try support as the machine is only 4 months old. Thanks.
Edited by GuestIt could also be that the nut that holds the encoder in place has been tightened a bit too hard. Push the knob off by using a screw driver from the inside of the printer, through the small hole in the transparent case. Then try loosening the nut you see in there a quarter turn or so. See if that helps.
Thanks iRobertl. Unfortunately that has made no difference. I have tried ever so slightly bending the spindle but realise it is very soft (aluminium) so don't want to make it worse. It definitely needs a new spindle so still looking for one.
You can try to print it?
https://github.com/Ultimaker/Ultimaker2/blob/master/1244_Knob_Front_(x1)/B1244-B2P-A.PDF
Also with the part number '1244-knob-front' you could order one from any ultimaker distributor afaik...
https://github.com/Ultimaker/Ultimaker2/blob/master/1245_Knob_Housing_(x1)/B1245-B2P-A.PDF
Edited by GuestThanks, but it's the aluminium spindle I need not the knob.
peggyb 169
have you tried to look underneath the printer if the panel where the wheel is attached to can be shifted a little?
because: is the hole in the wheel off centre or is the placement in the front panel off centre?
