Dim3nsioneer 557
Check both the material settings in the UM2XT+ and Cura... some settings are affected by both (I recently run into that issue with the fan speed).
It is strange that the material setting is only 50% I have never seen this before, what happens if you adjust it to 100%? @JohanP
Slowly after 20cm, it looks to be a normal print.
I made new program with new Cura, where it will also be just 50%.
What have I changed and where do I fix it?
tinkergnome 927
Most likely the "Flow %" in the material settings (on the printer), at least you can check that.
Was this the first time that you've installed the tinker firmware? I don't know, how many settings you have customized, but if you switched back and forth between standard and tinker firmware recently, a factory reset would be the best choice (the stored settings in EEPROM are not longer compatible for the "+" models).
- 1
Thank you, you were right, it was the flow was changed.
And I've done a factory reset.
Back on the track
Top Posters In This Topic
22
10
9
9
Popular Days
Mar 14
7
Mar 13
7
Mar 8
6
Mar 11
5
bob-hepple 22 posts
bondtech 10 posts
chrisw 9 posts
neotko 9 posts
Popular Days
Mar 14 2016
Mar 13 2016
Mar 8 2016
Mar 11 2016
Posted Images
00D00B 58
Ok ! I guessed it was this way but prefered to ask anyway (:
