You need to use really thin oil like sewing machine oil or 3 in one oil
To get it free and moving again the best method is to wet a cloth in the sewing machine oil and wipe the shafts. move the head around and repeat. The new oil on the cloth will soften and help remove the old oil and will re-lube it at the same time. Just keep changing to a clean piece of cloth every time you wipe it.
1
peggyb 169
Did you clean the rods and do they move again?
A thin oil like bicycle/sowing machine oil should work fine, Apply the oil, move the head around in all directions and remove the left over oil, especially if this turns black.
