I did it like this ...
https://www.youmagine.com/designs/timelapse-gopro-tools-for-um2
To answer you question, The printer is driven down. you could make it so it will stay up but its better to design a mount where it doesn't move with the build plate. This way its always looking at the business end where you can see any problems with the hotend. Ones that move with the plate on tall prints, you cant see the hot end very well.
@APRP, the bed is either driven down or gravity does it(not sure on UM2e), but either way, you can use Gcode to make sure it doesn't. For example in my UMO end code there is:
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
So I imagine if it's driven down there should be a line that either G28 Z0 (if homing is done downwards), or another command, some UM2 owner would have to fill the gap here.
Remove that.
And also remove the steppers off M84. Then I think the build plate should stay in position, as the steppers are still powered.
Again I'm not 100% sure, but something like this could work.
Yes it is it is just gcode that does it. On my printer, on print completion, it is setup so that the print head is homed but the bed stays where it is; I then manually home the z axis but that could be done by a gcode command that just moves the bed to another position.
there is a bolt on the bottom back of the platform, I guess this one triggers the z-limit switch, maybe a longer one? Could this work?
gr5 2,069
There is a small amount of space when all the way down - about 1cm. Can you design your mount to use no more than that much space?
