Hopefully we'll have a lot of entries of UM2 owners then
ended Community Contest | Win an Extrusion upgrade!
count me in for this one, or at least kick start it with this little thingy.
https://ultimaker.com/en/community/prints/3184-biljart-snooker-element
I tried embedding the code but it does not seem to work.
Edited by SandervGI added it for you. Why didn't it work?
I copied the embed code (next to share) and just pasted it in the text editor
1
thnx sander, ooh, it's that easy? I used insert code and pasted it in there but that didn't do the trick
the upgrade may fit an UMO+ too. But this needs to be tested first, not sure. (or it could be a challenge for you to make it compatible if you win)
I think I can guarantee this will not work. Based on the that fact the the UMO+ PT100 needs a 64inch cable while the UM2 PT100 only has a 42inch cable. I know because I've seen 3 different UMO+ kits that had the UM2 pt100 stocked accidentally. Sadly on the 1st two we did not realize this until everything was put together and we were routing the cables to the circuit board and came up WAY short! We had to take the PT100 cable out of the spiral wrap and run it straight across the top of the machine and down to get the machine working. On the 3rd kit I measured the pt100 before assembling, saw the issue and got the right one shipped before this mistake happened again.
Well pt100 cables ain't like thermistors you can solder an extension and it works (been there done that) also if you already have a pt100 you can just use it.
Now that I check my umo, the pt100 cable has some extra unnused distance on my board. I'll check that.
Ohh I see. That's easy to fix! Just assemble the cable through the other side. Not biggie. Umm the board it's on a different position that must be 10cm.
Well a fast fix could be just taking the cable out of the wrap and not inside the black cable wrap and installing it using the other cable hole.
So um2 cable it's 1m and umo+ 1.5? I'll check the githubs
No it's not:
https://github.com/Ultimaker/Ultimaker2/blob/master/1185_PT100_B_sensor_(x1)/B1185-B2P-A.pdf
More than enough distance.
Um2go it's 1m
Also if the kit it's also for extended um2, there's no way it could be that short. Maybe @sandervg or someone with the kit can meassure the pt100 cable length.
Edited by GuestWell pt100 cables ain't like thermistors you can solder an extension and it works (been there done that) also if you already have a pt100 you can just use it.
Good point, I'm just worried if all the cables are similarly shorten for the UM2 you will have more work to make it fit. Notice the new placement of the extruder motor is also closer to the board. So some hole drilling and mounting would be needed.
BUT if all it takes is soldering an extension on the PT100 this would be the way to go since supposedly the upgrade has a "new PT100" which is much more accurate then the previous one.
Actually if @sandervG is looking for UMO+ testers, I bet he could find some without looking very far. :-)
I have two um2 feeder motors on my umo+ and the cable it's shorter, but it's just good enough. If they made it shorter then it will need a lower assembly, but I have designed a thinkgy that allows to install it outside on a lower position.
Wow too much to design!
Well all I know is we had 3 different UMO+ kits with 42inch PT100 cables, and support's explanation was that these were UM2 parts and that's why they were too short. maybe they were from the UM2Go.
If the "normal" UM2 has a 51inch PT100 that might be workable if you move the extruder to the left side from the right.
Here is my design for the contest.
Filament Guide for Ultimaker 2 - Final version
This guide is used when the spool is rotated by 90 degrees behind the printer. The 90 degree rotation can be usefull force the filament ripples of the extruder to the side of the bowden and PTFE coupler. This mod helped me to get rid of a lot of underextrusions as the friction of the ripples inside the extruder was very high.
I guess this one is pretty much for UM2 owners (again)
Good luck out there.
No need for us to worry @Titus!!! Extruder update kit, still trying to keep up with our old UM orginals
Can you combine your work with preciousplastic and as a teacher to come up with an entry @3DCase?
If not for the fun, it would be an interesting challenge to see if the extrusion upgrade fit an Ultimaker Original!
1
It's a bit off-topic but I just measured a kit I have here and the PT100 was 116cm (give or take a cm or two). I might be able to measure on another kit tomorrow at work but I'm assuming they'll be identical.
1
Thanks @IRobertI
I think that would be the one that is too short for the UMO+, I would get the longer one before you start putting that kit together.
I just got one of my spares out and measured it at 153cm.
I think we're high jacking this wonderful thread. :-( Should we start a "UM2 upgrade kit on the UMO+" or something?
116cm well.. There's a way to make it much shorter in seconds. Separate the cables from the bowden and make them less curved. That will cut 20cm fast. Anyhow it's quite easy to take out the pt100 from the olsson and put the one from the umo+, not ideal indeed. Other idea could be to rotate the umo+ board and make a printed enclousure for the board, making 4 drills on the wood and taking the opportunity to add a fan for the board (because the summer in Spain will be hell)
Edited by GuestHello,
This is actually my first post here. I have had my ultimaker 2 for about 6 months, and am loving using it. Of course I have had some small issues, but I have always been able to figure out how to fix them with browsing the forum and finding answers.
Anyway, I have run into a problem lately with my coffee pot not working the way that it should. The coffee pot is a commercial grade, with the spout on the bottom (see pictures). The problem is that I could not get a cup of coffee under the spout because it sat down too low. With a little time spent in front of my CAD software, I created a perfect solution... A Clawfoot Coffee Pot!
5
I'm in @SandervG ,
See if I can pimp and finetune my dual printhead, you never know how a 'cow catches a haze' .
1
Please don't let me win
[print=3143][/print]
3
Got some time and did some simple checks. It's imposible that an um2 pt100 cable can't be installed on a umo+. If reach the um2 board on a side it can also on the other.
The main difference on umo+ it's the cable must take a longer 'curve'. But if the idea it's to implement the whole kit seems totally doable by making a cable guide and making the bowden go near the frame like on um2. Also I did a design for a extruder holder that can be easily adapted to hold the feeder geared extruder on the um2+ kit. On the same area (mirroed area)
This clips using the already existing screw of the wood structure and hang to the cable hole without blocking the cables. I did use this for a time when experimenting with different spool holders and I was able to put 2.2k colorfabb rolls without any issue, so it can hold an extruder.
SandervG 1,519
I remember someone saying taking part of a contest and learning something is already rewarding, and the upgrade may fit an UMO+ too. But this needs to be tested first, not sure. (or it could be a challenge for you to make it compatible if you win
Titus 170
I wasn't saying I wasn't thinking about it
Just that an UM2 owner should get the prize!
