Another drawback of curaEngine is that every single setting must be set on the command line. There is no ini or config file option for loading these settings.
Not true. You can send it .ini files
Nallath, can you elaborate how to pass .ini files to the cura engine command line slicer? When looking at the help page (CuraEngine help), I don't see any option to pass a ini file.
If this is not possible to add the ini file, I wonder if it is possible to add the ini variables to the json file provided in the Cura/resources/machines/ directory.
nallath 1,080
That's because it's a GUI application, not a command line one
Streaming g-code to the printer isn't that hard of a task. I'm pretty sure you can pipe the results from the engine into a serial connection (So a single bash script should do the trick).
