sending an STL or GCODE directly to printer by command line
JewelryMaker
Posted · sending an STL or GCODE directly to printer by command line
pronsole in protorface is having the option to print any of the gcode file.
usually we give 3 commands as below
load /path/to/the/gcode
connect COM8 125000
print
Do Cura has such options using which we can run it from the command prompt.
Thanks & Regards,
Debakanta
    connect COM8 125000
    print
    Thanks & Regards,
    Debakanta
    connect COM8 125000
    print
    Thanks & Regards,
    Debakanta
        • 4 replies
