incomplete gcode, cannot save on sd card, print stops too early
derPotz
Posted (edited) · incomplete gcode, cannot save on sd card, print stops too early
Hi. Does anyone has the same issue with Cura not working properly?: A stl put into Cura appears to get transformed into pathes/layers ok (pic 1) 5a3319991478b_stlincura.thumb.JPG.df3ca139820c1c624d2bdb4282dfb2ff.JPG
- but fails to save on SD-Card. It`s possible to save it on harddrive - but when opening that gcode in Cura it shows (2nd pic) 5a33199928a29_savedgcodeopenedinCura.thumb.JPG.d0de15bddaf1f9903e1c5ea487b35921.JPGthat there are layers missing so that the printer is stopping then. The stl is fine - no open edges or else... checked with Rhino and netfab. Also the walls are at least 1 mm -using a 0,4mm nozzle. Happened with different stls. Any hints where to search the cause for this? I use a very good PC and Cura 15.04.4 (-and didn´t have the issue with former versions...) Thanks, Lars
    Posted · incomplete gcode, cannot save on sd card, print stops too early
    let's see, you can always try a "file / Reset profile to default" to make sure you did not do anything strange to settings.
    Next thing to play with are the "fix horrible" in the expert settings, think these can cause some strange behavior.
    Did you view your model in X-ray mode?
    "file / Reset profile to default" not available in 15.04.4
    "fix horrible" ...?! if you mean repair options : didn´t change outcome
    Tried reinstalling cura and also with older versions of Cura - same problems...
    Xray looks fine
    Sclicing Engine says(I don`t know how to find an error there...)
    Running: C:\Program Files (x86)\Cura_15.04.4\CuraEngine.exe -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode= -s supportXYDistance=700 -s insetXSpeed=80 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s gcodeFlavor=1 -s postSwitchExtruderCode= -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s skinSpeed=30 -s inset0Speed=40 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=4 -s initialLayerSpeed=30 -s minimalLayerTime=3 -s infillSpeed=100 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=2850 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=18000 -s extruderOffset[1].Y=0 -s layerThickness=150 -s endCode=M25 ;Stop reading from this point on.
    ;CURA_PROFILE_STRING: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
    -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=1500 -s skirtMinLength=0 -s objectSink=0 -s retractionAmount=4500 -s nozzleSize=400 -s skirtLineCount=0 -s startCode= -s skirtDistance=0 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=0 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=150 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=-1 -s insetCount=2 -s downSkinCount=4 -s multiVolumeOverlap=150 -g 49674 -m 1.0,0.0,0.0,0.0,1.0,0.0,0.0,0.0,1.0 -s posx=115000 -s posy=112500 $
    Cura_SteamEngine version 15.04.4
    Copyright © 2014 David Braam
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU Affero General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU Affero General Public License for more details.
    You should have received a copy of the GNU Affero General Public License
    along with this program. If not, see .
    Default config 'default.cfg' not used
    Reading mesh from socket with 459630 vertexes
    Loaded from disk in 0.344s
    Analyzing and optimizing model...
    Face counts: 153210 -> 152786 99.7%
    Vertex counts: 459630 -> 76449 16.6%
    Size: 202.458000 202.458000 17.000000
    vMin: 13.771000 11.271000 0.000000
    vMax: 216.229000 213.729000 17.000000
    vMin: -101.229000 -101.229000 0.000000
    vMax: 101.229000 101.229000 17.000000
    Matrix: 1.000000 0.000000 0.000000
    Matrix: 0.000000 1.000000 0.000000
    Matrix: 0.000000 0.000000 1.000000
    Optimize model 0.327s
    Slicing model...
    Layer count: 112
    Sliced model in 2.917s
    Generating support map...
    Generating layer parts...
    Generated layer parts in 0.562s
    Generated inset in 4.524s
    Generated up/down skin in 6.131s
    Wrote layers in 16.10s.
    Wrote 2.7 kilobytes.
    Total time elapsed 30.90s.
        • 6 replies
