I just use normal office printer paper.... always available and works fine... and as it has some structure you feel the smallest friction very good.
1
Use a z-offset command, you can't lose that; if you delete it you just key it in again!
MajorKoos 3
I'd guess it's intended to be 0.15mm
I measured mine as 0.14mm with some digital calipers.
Try getting a "feeler gauge" from an auto-parts shop. They're used for setting the gap on spark plugs.
SandervG 1,519
But get two instead, in case you loose one again
Also it could be an idea to develop a feel for the levelling of your bed on eye sight. You'll probably learn it through experience, but in that case you wouldn't need an aid anymore at all
