Thanks Tinkergnome, I'm pretty sure its not an issue with the trigger screw because I didn't touch that bottom part of the buildplate and its not moving at all when I turn it down.
I measure the continuity and seem to be registering an electrical path when its off (open) and on (pressed down, with click). I also tried to measure resistance and it seemed it may have been the same in both positions, though I found it difficult to get a stable reading with my multimeter so not sure how much stock to put into that.
Anything else you recommend, I also did a factory reset and updated firmware.
tinkergnome 922
The limit switch at the bottom is triggered by the small screw at the back of the buildplate. After that the axis is backed off by 7mm. The error message means, that the endstop is still triggered.
If you have replaced the heated bed - is anything different with the "trigger-screw" now?
In addition: "connection looks good" means nothing...
Can you test the endstop switch with a continuity checker?
