I think it would be rather difficult to port Cura to IOS.
I guess a port might be a lot of work indeed, but maybe an app which uses cloud based processing (which I think would require less programming) is easier to make? Having the possibility to upload your .stl, change the parameters and download a gcode, should be obtainable I think?
This approach is a bit similar to what Glowforge is planning to do I think, and likely more examples can be named.
nallath 1,120
