And can you share a close up picture?
I didn't change any settings at all other than layer height when I first used the .25 nozzle. I think when you set nozzle size in cura it automagically sets first layer height n such to adjust for it.
It sounds to me like maybe you didn't tighten the nozzle when you put it on. (I made that mistake once.) Also, maybe increase temperature +5 degrees? it could be it was a tad too low before, but sufficient to still push out the larger diameter nozzle opening, but the smaller one wasn't.
If you are in expert/full settings view in Cura and you only change the nozzle diameter manually, your print will fail. But if you use the quickprint settings for 0.25mm for the UM2+ (lower speeds) everything should be fine.
darkdvd 974
UM2 or UM2 + ?
