Make a modle of the petal that is 0.35mm thick , the default setting for 1st layer is 0.3 so that should make a single layer print.
Also if I misunderstood, post the link to the file your trying to print. This would help.
If you mean "single wall" then try "spiralize" setting in the expert menu.
ultiarjan 1,216
I don't understand your question.... are you mixing the terms walls and layers? What exactly are you trying to achieve?
