Looks like your bed is simply a bit too far from the nozzle. Try running the bed leveling wizard again or manually adjust the three thumbscrews underneath the build platform while the printer is laying down the first layer.
That's assuming that the top layer and sides of the print look good.
Hmm, ok. the top layer and the sides are all good. I thought my nozzle was pretty close - doing the whole slide a piece of paper between the bed and nozzle trick - but ill give this a go, thanks
IRobertI 516
gr5 2,070
Don't run bed leveling - just turn the 3 screws 1/4 turn counter clockwise as seen from below. You want the bottom layer squished slightly - not rope shaped. You want it more pancake shaped.
To get stunningly perfect bottom layers takes a lot of experimentation but basically you want to change the bottom layer thickness from .3mm to .1mm and you have to play with those 3 knobs whlie printing the first layer and you have to cancel the print and repeat maybe 10 times until you get it perfect. If you do the leveling procedure you will wreck it and have to start over. Basically with a .3mm bottom layer thickness getting the bottom layer accurate to .2mm is okay and accurate to within .1mm is great. But with a .1mm bottom layer you want to get the leveling accurate to about .03mm which is incredibly accurate for this machine and might not be achievable (tiny warps in the rods and glass).
Anyway stick to .3mm bottom layer for now and just move that glass up a 1/4 turn.
What temp was your glass? For PLA I recommend 60C - for ABS 100C.
IRobertI 516
I'm sorry, what? I guess I've been lucky for the past couple of years and literally hundreds of machines I've done it on?
