Thank you for the quick reply.
Ok here goes, I can print fine using an SD card in the UM2+, When I try to use octoprint I do see a red and blue line on the temperature graph so I assume it is getting a temperature reading. I can upload a file the press the print button button and looking in the logs the status changes to "printing" the printer does not start moving and no plastic is released from the nozzle. Eventualy I get a timeout error in the logs.
gr5 1,967
Yes reprap/marlin/sprinter is correct.
We need more details. Have you gotten the printer to work through the SD card?
What doesn't work through octoprint exactly. Is octoprint able to read back the settings of the printer such as temperature? Does the printer start moving when you tell it to print but no plastic comes out? More details please.
