Startup Nozzle Temp 20-22 degree's
Ronan
Posted · Startup Nozzle Temp 20-22 degree's
This is for an ultimaker 2+ Extended.
So my nozzle temperature shows 20-22 degree's on startup when i go in the maintenance section to 'heat nozzule up' to do a atomic pull.
Is that normal? Shouldn't it say 0 degrees since the printer was off (has been off overnight)... I'm not at the workshop so i can't compare against the other printers...
    It's reading the temperature that the nozzle is currently at which should be the room temperature. Hot days it will be higher and cold days lower :)
    • Like 2
        • 6 replies
