http://www.abload.de/image.php?img=ixa30.jpg
this is the only picture i have, sorry
i print with the standard settings of pla with 25mm/sec (faceplate), um-robot is the original g-code on the sd-card
Edited by Guesthttp://www.abload.de/image.php?img=ixa30.jpg
Labern 765
Do you have pictures of your failed attempts. They can be easily added in a post.
I'm not sure if i understand your problem correctly but There are different things that can cause some of the issues you have explained.
If you print thinner layers then you need to reduce the print temperature as the material is moving more slowly through the hot nozzle.
This is the same if you have a slow print speed.
The Antenna on the Robot can be difficult to get really nice. There are different ways to get nice results on small items. Printing slow and cold / printing 2 items at once / Printing a small tower next to the Print or adjusting some of the minimum layer times and cold head lift options are all ways that can help with some of these issues. The best option can depend of the type of the print you are doing and this is something you just get a feel of the more you print.
