Thank you, i will try to lower the build temp.
I am not sure if the elephant feet is the issue, since to me it seems to 'peel back onto itself' on the edges, but maybe thats a side effect of the elephant feet after hours being heated at 70 degrees...
I will try tonight
jechsturk 3
Hi Ronan,
I think your problem is called Elephant feet (see image below).
What you can do to prevent this, is turning down your bed temperature, or make the gap between your bed and nozzle a little bit bigger.
Normaly i print PLA at 60°C bed temperature (PLA does stick very well to a degreased glass plate, so high bed temperatures are less necessary than with ABS for example.)
Prints with a big touching surface between the glass and object even lower, about 55°C bed temperature
Hopefully this helps you out!
