fbrc8-erin 316
The other thing that gets a lot of wear and tear is the bowden tube itself. If you remove both ends from the printer and slide a piece of fresh filament through by hand, you should be able to move it fairly well. If you encounter any resistance points...there may be damage in your tube. Also, check out the photo here of the bowden tube: https://fbrc8.zendesk.com/hc/en-us/articles/205658894-Maintenance-How-Do-I-Maintain-My-Printer-
If the feeder end of your bowden tube is starting to look chewed up, you may want to go ahead and trim the end. Use an exact-o knife or similar to trim the last few millimeters and then widen it out to 45 degrees.
IRobertI 521
You're not going to be able to compress it just by pushing, it's too strong for that. To increase pressure you turn the screw counter-clockwise which might be a bit counterintuitive. Generally the white indicator should be at the top, where the pressure is lowest.
But I doubt this is the issue. It's more likely you have a blockage in the nozzle. I would start by doing a few "Atomics" which is a method we use to clean out the nozzle. You can read about it here:
http://support.3dverkstan.se/article/10-the
You want the plug to come out clean, or close to it. White is a good colour to use for obvious reasons.
If the printer has been running for a long time (a few hundred hours) it could also be time to replace the PTFE coupler which is the white piece in the middle of the print head. With time it deforms and causes friction.
Edited by GuestLink to post
