fbrc8-erin 316
Do you have a contact probe temp sensor to verify that your nozzle is getting to the temperature the printer thinks it is? I recommend a contact temperature probe rather than a UV one for more accuracy.
The other way to test and see if it might be reading off is to see if raising the temperature makes a difference.
derek-bosch 1
still having major issues, the feeder itself seems fine, can push filament without the hot-end in play...
after I've cleaned the nozzle, atomic-pull, etc, a print will go fine for the first couple layers, then the print will get less and less dense until it finally stops extruding anything from the nozzle.
I've replaced just about everything in my UMO hot-end. Nozzle, Aluminum block, PEEK, brass pipe, PTFE coupler...
I'm wondering if my thermocouple might be bad - is there any way to diagnose this?
it is just about the only thing I haven't replaced!
really need help here, as I'm getting ready to chuck my UMO with a trebuchet
