Spliced object not aligning
jpm021990
Posted · Spliced object not aligning
Hi, @jpm021990, well as I said earlier it is your printer. I did a test run of both parts and they fit together neatly with no under/overlaps at the perimeter. Not the easiest of prints though, I did struggle with 1st layer adhesion, which I don't, and a lot of strange infill movements from Cura.
