Hi gr5,
thanks for reply. I wonder why the result is that bad. I use Autodesk Fusion 360 to create my items and export at STL - I never had probelms with it.
thanks for the tip using the X-Ray view may this is a good indicator.
I never used x-ray view only layer view.
Thanks a lot!
gr5 2,167
Your stl file is faulty.
NEVER PRINT A FILE without looking at it first in "layer view". You would have seen the problem right away. I looked at you gcode file - it looks horrible - just like your print. If you look at your part in xray view you will see it has an extra face (it's not a printable part as is - it has an interior curved wall) and cura doesn't know which is inside and which is supposed to be not printed and it gets very confused. Remove the red wall and that should fix the problem. here is xray view:
RED IS BAD. It means passing a line through your part hits an odd number of walls so it either has a hole or in your case an extra wall.
