Varistor on the USB port blown?
fnorkn
Posted · Varistor on the USB port blown?
Hi
I started a thread about a busted sensor earlier, solved that problem by replacing an opamp. I think the cause was a shortcircuit on the usb port.
Now I want to upgrade my firmware by using the USB port, but it is no longer responding.
Not to worry, I have purchached an AVR programmer and successfully downloaded the firmware from the chip using ICSP1, so I can change the firmware.
But I would like to get the USB connection working again. Just for the hell of it.
I did some measurements, and want to check with you guys about assumptions. Here is the pic of the board (the blown coil L1 is bypassed with a piece of copper foil) :
Here is a piece of the documentation:
Now I assume that R8 and R9 are varistors, and are there to lead away spike voltages on the datalines to ground?
R9 is not conducting according to my multi-meter (good) but R8 is 33 Ohms. So D- is not getting through to the atmega 16u? So I think I should remove it, and see if the USB connection will work again?
Also, C6 seems to be busted. It is connected to the evaporated L1 coil, so I checked it out. It should be 1 uF according to documentation. The multi-meter says it has infinite capacity, which usually means it is blown. Indeed, I measure 3.4 Ohms, not good for a capacitor. I am not really sure what the UCAP port does, it does not seem critical to me for USB communtication, but I could be wrong?
Suggestions are welcome!
    Posted (edited) · Varistor on the USB port blown?
    I removed the varistor and the capacitor.
    When I measured them again, detached from the board, the values were OK.
    So the problem is a short circuit somewhere else. Could be the atmega chip, perhaps the USB input ports are fried...
    Desoldering this chip is not something I am really looking forward to, and if I need to replace it , I probably need to flash the eeprom, program, "fuses" , boot-loader (?) etc (I am used to PIC microprocessors, atmega seems to have its own way of doing things)
        • 4 replies
