Endcode for moving the Z-axis.
Posted · Endcode for moving the Z-axis.
Hey Forum,
I have asked this question before, and backthen got an answer that i found not to be working.
I might have done it wrong, (im almost sure, because i dont yet fully understand the gcodes) so therefore i seek additionel advice.
Last time i asked for an endcode that moved the Z-axis to the bottom max position, i got that i should write "G162 Z" in my endcode.
My endcode looks lige this :
; Default end code
G28 X Y ; Home x and y axis
G162 Z ; Send printbed to bottom max
M107 ; Turn off fan
; Disable all extruder
G91 ; Relative positioning
{IF_EXT0}T0
{IF_EXT0}G1 E-1 ; Reduce filament pressure
M104 T0 S0
G90 ; Absolute positioning
G92 E0 ; Reset extruder position
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
I cant figure out if some of the following codes mabye disable the command.
Can anyone help me with writing an endcode that sends the printbed to bottom max when done printing.
Thanks guys.
    • 3 weeks later...
    Okay, thanks.
    But what do i write and where, to send the z-axis to the bottom?
    I know that the bottom max is about 200, but how do i put it into the endcode so it Works?
    • 4 weeks later...
    Sorry, ive been out for a while.
    Yes, i have an UMO+.
    I have not tried it, but im going to when i have some more time on my hands.
    but as i read, i should write "G28 Z" instead of "G162 Z" right?
    Posted (edited) · Endcode for moving the Z-axis.
    G1 Z200
    will work.  That tells the z axis to "go" to position 200mm.  G0 and G1 do the same thing.
        • 4 replies
