A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
SandervG 1,519
Hi, and welcome to the forums
Is it literally in pause-mode or did it just stop printing?
Like; can you resume your print when you arrive at your Ultimaker?
Have you checked the PauseAtZ plugin in Cura if that is not accidentally activated?
What kind of 3D printer / Ultimaker do you have?
Is it the same file or different files?
If you use an Ultimaker Original, do you still print through USB?
Lots of questions, but they should help isolating your issue.
Thanks!
