Offset of the y -axis during printing.
GOO
Posted · Offset of the y -axis during printing.
Hello there,
I have a UltiMaker Original Plus and i''m having problems during printing.
During printing, after approx. 1 hour printing the y coordinate is displacing.
I have checked all the axis and pulles and this doesn't cause the problem.
Does anyone know's what causes this problem and how to solve it?
I hope to hear from you.
    Did you check also the pulleys on the motors? Also check if the belts have any oil, if so clean with alcohol.
    It can sometimes be due to the steppers getting to hot or if you have a travel speed to high.
    You can prove if any of the pulleys are slipping buy marking the shafts and pukkeys and checking them after it has skipped. If this is ok and it's always after about 1 hour I would think that they are over heating.
    • 2 weeks later...
    Hi Labern
    i check the pulleys they didn,t slip
    Used a extra cooling fan on the steppers problem solved
    many thanks
    Hi Labern
    many thanks
    Sounds great. Happy printing.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
