I had this problem on my X stepper. Thank you for your amazing analysis and contribution!!
Gerrie
Gerrie
Another easy solution is to drill some holes in the electronics cover, to allow air to flow in directly under the drivers. I did this after noticing that the boards around the drivers on my UM2 were turning overheat-brown.
For some reason, Ultimaker did not bother with adequate ventilation for the electronics, as least on my UM2.
gr5 2,094
They are certainly aware that some steppers - especially the Z stepper overheat. when they do overheat they turn off for a few seconds and the table falls down and you get bad results. I think something must have changed in this circuit because it works fine for most people.
In the latest firmware I believe the currents are default to 1000ma (close to your suggested 918ma) and if you call support complaining about these problems they recommend lowering to 1000ma. I will call attention to this posting - thank you very much for this in depth posting - and let both the hardware designer and the firmware designer know of this. Unfortunately if the older boards use one resistor and the newer boards use a different resistor then I don't know how they can tell who has which!
kadakada 0
Thank you. 1000 mA is much closer to reality.
The default current settings of latest firmware are:
X,Y: 1200 mA
Z: 1200 mA
E: 1250 mA
It's better, but still too high I think if interprets 1200 mA to real current of 1739 mA.
Edited by GuestLink to post
