V2 Hot End
futurejames
Had some questions about assembly.
Do I have to replace all the wood on the head? Or can I get away with just changing certain pieces (like the top and bottom).
Any tips on pulling out the old thermocouple and cartridge heater from the old aluminium block? Should I heat it up before trying to remove?
If there's anything you found to watch out for, or anything to make my life easier, please let me know.
    Mhh, you _should_ at least replace all the wood on the head. Can't say if it is possible to kludge something when not doing.
    For disassembling / pulling out the thermocouple and heater (and all party that get heated in use) -> it's always a good idea to warm / heat things that you need to remove, be it "slid in" or "screwed in". Ask any car mechanic :-)
    Regarding to the wood, it is not necessary to change the sides of the housing.
    The new wood has, i believe, 2 new small holes in it what makes it easier to guide wires from the outside with a screwdriver. If you don't want this luxury you don't have to swap them :)
    The top and bottom are mandatory tho.
    As for further guidelines i would like to refer to the wiki and look at the pictures.
    Don't use any excessive force for anything but make sure the hot end part is tight.
