What temperature and speed are you using for the print, and how is it oriented on the bed?
Is there a specific reason you used the 0.6mm nozzle?
I am printing at the Cura Defaults, and I meant 0.4 nozzle (sorry). See below. As far as orientation, it is the same on the MB (shown below). Temp is not in Cura that I can see, if I hit tune on UT, and select Temp, it is 210C. Odd I can't find temperature in any settings on Cura.
SandervG 1,518
