I just disconnected the blue and purple connector from the PCB and connected it to the electronics fan connection; the fan spins so the wiring is right from one side to the other.
I measured the voltage at the nozzle fan connector in the PCB and it is 19.4V when fan speed is 0, and 14.4V with speed at 255. As far as I know the fan should be spinning in any of both cases, right?
gr5 1,967
If it spins at 9V and it is now 14V it will certainly spin! So if you see 14V the fan must not be connected.
I would ohm out the wires one more time end to end (under the printer to fan) - each wire. Just to make sure you repaired it properly.
But it's probably the darlington transistor: Q4 - this fails easily and can fail in two possible modes: always on, always off. You may have it failing in the "always off" mode. Or you didn't properly repair the wires.
Part number BD679.
http://www.digikey.com/product-detail/en/BD679/497-5776-ND/1300084
schematic here:
The circuit diagram, and board layout are here:
http://reprap.org/wiki/Ultimaker%27s_v1.5.7_PCB
There is a zip file at the top. It contains the "brd" file which is the layout. Also the "sch" file which is the schematic.
Both files can be opened by eagle software which is free:
http://www.cadsoftusa.com/download-eagle/
