Cura not connecting to printer
DanJenG60
Posted · Cura not connecting to printer
hello all,
new to printing and just finished assembling my afinibot delta printer, which is essentially a micromake d1? i installed cura but when i go into the machine debugging setting its not letting me do anything. the setup information that came with the machine says this is a common issue but i cant seem to find a remedy for this. any help or suggestions is greatly appreciated.
thanks
    i had to manually select the com4 port in the machine definition setting, now i can control the printer using cura. now the issue is when debugging the drivers they will not home, instead of moving upward to the limit switches they move downward. this is a delta printer, that is being a real pain
        • 10 replies
