On all my 3 umo+ I use 303 tooth belts, with UM2+ hotends (modded) and they fit well, using the same central shafts align like um2.
(don't mind the print quality much, since I print this stuff as fast as possible)
This is the latest Neo-Gudo slideblocks:
This ones only work with open belt, I had to cut some tooths (like 3-4 I think) to use it. Also I have another version that is for closed belt. I think open belt is quite nice, being able to tighten them is quite nice. But also, the closed belt did work without loosing tension for a year+ and I print a lot.
But ofc, this new slideblocks use M2.5 screws, otherwise they would use more space. The advantage ofc, is that you gain a few mm on print area, and changing the endstops + firmware you could use the long central shafts of a um2 to use the whole bed like a um2. But so far I never did that mod because I never print anything bigger than 20x20
Edited by Guest-
1
neotko 1,418
I have two slideblocks that I made with @Gudo
One is for fixed length, the one used on the mxl to gt2 mod page, and other that we did for open belt with tension adjustment.
So, you can go either way.
I will upload a new Beyond Slideblocks soon, but if they aren't inline when you need them drop me a pm.
drayson 75
Thanks for feedback!
The only thing I fear is that the 303 teeth, 606mm long closed loop belt too short to be clamped with the "beyond V4" block - which I'd like to use to change the upper/lower position of the xy-rods to be able to use something like a "UM3-style" head without interfering...
