Cura 15.04 Plugin to edit first layer
Ddot
Posted · Cura 15.04 Plugin to edit first layer
I have a Ultimaker 2+ (upgrade kit). I am printing tiny parts, and have been trying to use the plugins to modify the first few layers. However, I am having some difficulty with using these plugins:
Once I add a "Tweak at Z" step/plugin, there seems to be no way to remove it. How can I delete specific plugins? The only workaround I've found is to previously save the profile, and reload an old one with less/no plugins.
What parameters do I use to start the modification during the first layer? Specifically, I want to modify the temperature and overall speed for the first 4 layers, then thereafter to on as normally set. I have tried setting "z height to tweak at (mm)" to -1.0, 0, 0.0001, and this step/plugin does not seem to engage. Instead, the default settings from Material.txt override this first plugin. I have tried also setting "(ALT) Layer no. to tweak at" to -1, 0, and 1, and again, this first plugin does not engage. The proceeding plugin(s) that I set to start at Layer no. 2 or 3 does work perfectly fine.
Derrick
    Grab the edge of the left panel of cura and drag it to the right. A tiny little "X" will appear at the top right of the plugin which you can click to remove it.
    Posted (edited) · Cura 15.04 Plugin to edit first layer
    Nevermind, got it... was not interpreting "grab" as "expand". I'm a laptop so I don't see the "x" until I expand the panel so it takes up half of my screen.
    Any suggestions on the second question?
    Tweaking the first layer is possible with version 4.0.3 or higher.
    TweakAtZ 4.0.4
    Thanks for the reply! I will try out your tweaks on the tweaks!
    I spent the majority of yesterday playing around with the settings to discover that for the version I'm using (I updated it last week - 15.04.5, plugin v4.0.2), the tweaks happen after the layer # set. In other words, if I set "(ALT) Layer no. to tweak at"=2, then the tweaks will activate starting at layer 3. And unfortunately, layer 0 does not seem to be editable.
    Edit:
    Unfortunately, the code you linked does not seem to work, either. The first layer is still using the settings in Material.txt. When I set the plugin to start at layer 0, it again starts after layer 0 is finished, effectively applying the settings for layer 1 (the second layer).
