Getting a perfect top layer ist difficult. You usually end up with scratches and lines deposited during travel moves or both. Z-Hop and Retraction Settings, Extrusion rate, printing speed all needs to fit for it to work. To dial this in properly takes a while.
Here's a start: http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#scratches and heres some more: https://www.simplify3d.com/support/print-quality-troubleshooting/#scars-on-top-surface..
Hope this helps a bit.
I do wonder, how does the bottom of your object look, would printing it upside down help? First layer on naked glass usually comes out looking great..
Edited by Guest-
1
edible3d 1
Thanks so much Nicolinux I did level the plate so that part seems ok now the issue of the 'smooth' finish im after really want to resolve that :-(
Thanks again.
