Nozzle jammed
Posted · Nozzle jammed
Okay, I have a UM2 Extended and this machine will go down as the biggest piece of junk in history. I can not clear a jammed nozzle even after 8 or 10 tries at the atomic method. The forum has a lot of good info but not much on nozzle cleaning. What do I do now? I have other nozzles that came with my machine but how do you change them. The user manual is just about useless.
    and welcome to the forum.
    Which model do you have exactly? The Ultimaker 2 Extended+ or "regular" Extended?
    If it is the +, then you'd have the so called Olsson Block and you need to follow this guide:
    https://ultimaker.com/en/resources/18805-changing-nozzles
    If it is the regular UM2 Extended, you need this guide (skip to step 3.):
    https://ultimaker.com/en/resources/252-disassembly
        • 9 replies
