To fix the z mark you need to think like a slicer. How does it happen? Most of the time it's because the z changes without a retraction of the filament and this filament stretch makes some of the filament to follow, then the hotend starts to print making a change on preassure resulting on a z mark. New cura has 'coasting' that if works well it should help. Coasting stops the extrusion X amount before ending a loop, this way there's less filament on the nozzle before changing z and returning to extrude.
The problem with coasting it's that if too much will leave a hole, so it's a value that changes with temp/material/speed.
Other sollution that helps it's to retract before changing the z so there's less filament that can be stretched prior that z move. I don't use cura anymore so I don't know if they did that, but s3d does allow you to activate that option.
Also, since the z change occurs from infill to going to print the interior perimeter line, you could increase the perimeters so that mark its more hidden inside the print.
Other option on s3d it's to randomize the starts/end of each layer loop, this way the z change/resume never happens twice on the same spot.
nallath 1,118
What do you mean by moving it outside of the print? The z-seam needs to be somewhere on the print. We do our best to prevent the effect of the z-seam, but it's not like we choose to create one
