Going on that a 0.75kg roll is 30 euros. And that a full roll can be printed in 30 hours, on quality settings at high speeds. Which puts the price on a euro per hour for the materials.
But Joris prints a roll in a few hours if he wants, but he is insane
As for the printer, so far I've only seen the old extruder wear out. The new extruder with the bearing wheel seems to have less wear. And then, even if some parts wear, you replace the parts, not the whole machine! I've yet to see any machine to show signs of wear. Except for the one machine which needed belt replacements because of improper assembly (The belts where worn, because the pulleys where skewed)
SandervG 1,518
Hi Pablo,
Because the Ultimaker is a DIY-Kit, or at least has an open design you can always replace parts when needed.
A proper assembly, usage and maintenance is needed to reach the Ultimakers full attention.
The Ultimaker is not Plug & Play, the Ultimaker needs to be calibrated and settings need to be set.
Therefor it is hard to say, parts will probably not break, but there is a chance due to experimenting or wrongful usage some parts get damaged.
You could consider a spare hot end v2 (if you want to plan ahead).
Have you also taken filament and blue tape in account?
