Thanks @neotko
One more quick question. If I were to acquire new fan bracket from 2+ extrusion upgrade (horizontal fans instead of tilted), would it fit UM2 style printhead? My friend is buying the extrusion upgrade and he does not need new fan bracket, he uses a printed one.
1
neotko 1,417
3dsolex can sell you a 1mm shorter coupler.
3dsolex and ultimaker I think they both use the same tfm.
You can print a spacer 1mm shorter. I used one done on pla for a month. Plenty of time to print one on abs/carbon/xt/ngen
Bowden, indeed you could just cut the area that goes to the feeder (easier to do a bad cut there) but the entrance has a bigger bore to allow easier filament load, I use an exacto knife to do that).
Tfm couplers don't work well with the spring compresion it's better a spacer (printed or metal).
