Ultimaker Community of 3D Printing Experts
Am I wrong or this new Cura 2.1.2 doesn't support Delta Printers?
Posted · Am I wrong or this new Cura 2.1.2 doesn't support Delta Printers?
Ok, your using Cura 2.1.x. I'm on Cura 2.3 so the json file formats are not compatible.
You may consider upgrading to 2.3, its a lot faster with more functionality and less bugs :)
    I did it with 2.3
    Thank you @DaHai8.
    Could you please guide (or help) me generate for bed 200x200x300, it's my delta bed size?
    Thank you again !
    Posted (edited) · Am I wrong or this new Cura 2.1.2 doesn't support Delta Printers?
    Here's the Disallow Areas for a 200x200 Delta print bed.
    Brief Tutorial follows...
    ,       "machine_disallowed_areas": {           "default_value": [		[[-100.00,   0.00], [ -98.76, -15.64], [ -98.76,-100.00], [-100.00,-100.00]],		[[ -98.76, -15.64], [ -95.10, -30.90], [ -95.10,-100.00], [ -98.76,-100.00]],		[[ -95.10, -30.90], [ -89.10, -45.39], [ -89.10,-100.00], [ -95.10,-100.00]],		[[ -89.10, -45.39], [ -80.90, -58.77], [ -80.90,-100.00], [ -89.10,-100.00]],		[[ -80.90, -58.77], [ -70.71, -70.71], [ -70.71,-100.00], [ -80.90,-100.00]],		[[ -70.71, -70.71], [ -58.77, -80.90], [ -58.77,-100.00], [ -70.71,-100.00]],		[[ -58.77, -80.90], [ -45.39, -89.10], [ -45.39,-100.00], [ -58.77,-100.00]],		[[ -45.39, -89.10], [ -30.90, -95.10], [ -30.90,-100.00], [ -45.39,-100.00]],		[[ -30.90, -95.10], [ -15.64, -98.76], [ -15.64,-100.00], [ -30.90,-100.00]],		[[ -15.64, -98.76], [   0.00,-100.00], [ -15.64,-100.00]],		[[ 100.00,   0.00], [  98.76,  15.64], [  98.76, 100.00], [ 100.00, 100.00]],		[[  98.76,  15.64], [  95.10,  30.90], [  95.10, 100.00], [  98.76, 100.00]],		[[  95.10,  30.90], [  89.10,  45.39], [  89.10, 100.00], [  95.10, 100.00]],		[[  89.10,  45.39], [  80.90,  58.77], [  80.90, 100.00], [  89.10, 100.00]],		[[  80.90,  58.77], [  70.71,  70.71], [  70.71, 100.00], [  80.90, 100.00]],		[[  70.71,  70.71], [  58.77,  80.90], [  58.77, 100.00], [  70.71, 100.00]],		[[  58.77,  80.90], [  45.39,  89.10], [  45.39, 100.00], [  58.77, 100.00]],		[[  45.39,  89.10], [  30.90,  95.10], [  30.90, 100.00], [  45.39, 100.00]],		[[  30.90,  95.10], [  15.64,  98.76], [  15.64, 100.00], [  30.90, 100.00]],		[[  15.64,  98.76], [   0.00, 100.00], [  15.64, 100.00]],		[[ 100.00,   0.00], [  98.76, -15.64], [  98.76,-100.00], [ 100.00,-100.00]],		[[  98.76, -15.64], [  95.10, -30.90], [  95.10,-100.00], [  98.76,-100.00]],		[[  95.10, -30.90], [  89.10, -45.39], [  89.10,-100.00], [  95.10,-100.00]],		[[  89.10, -45.39], [  80.90, -58.77], [  80.90,-100.00], [  89.10,-100.00]],		[[  80.90, -58.77], [  70.71, -70.71], [  70.71,-100.00], [  80.90,-100.00]],		[[  70.71, -70.71], [  58.77, -80.90], [  58.77,-100.00], [  70.71,-100.00]],		[[  58.77, -80.90], [  45.39, -89.10], [  45.39,-100.00], [  58.77,-100.00]],		[[  45.39, -89.10], [  30.90, -95.10], [  30.90,-100.00], [  45.39,-100.00]],		[[  30.90, -95.10], [  15.64, -98.76], [  15.64,-100.00], [  30.90,-100.00]],		[[  15.64, -98.76], [   0.00,-100.00], [  15.64,-100.00]],		[[-100.00,   0.00], [ -98.76,  15.64], [ -98.76, 100.00], [-100.00, 100.00]],		[[ -98.76,  15.64], [ -95.10,  30.90], [ -95.10, 100.00], [ -98.76, 100.00]],		[[ -95.10,  30.90], [ -89.10,  45.39], [ -89.10, 100.00], [ -95.10, 100.00]],		[[ -89.10,  45.39], [ -80.90,  58.77], [ -80.90, 100.00], [ -89.10, 100.00]],		[[ -80.90,  58.77], [ -70.71,  70.71], [ -70.71, 100.00], [ -80.90, 100.00]],		[[ -70.71,  70.71], [ -58.77,  80.90], [ -58.77, 100.00], [ -70.71, 100.00]],		[[ -58.77,  80.90], [ -45.39,  89.10], [ -45.39, 100.00], [ -58.77, 100.00]],		[[ -45.39,  89.10], [ -30.90,  95.10], [ -30.90, 100.00], [ -45.39, 100.00]],		[[ -30.90,  95.10], [ -15.64,  98.76], [ -15.64, 100.00], [ -30.90, 100.00]],		[[ -15.64,  98.76], [   0.00, 100.00], [ -15.64, 100.00]]           ]       }
    How I Did It - by Victor Von Frankenstein
    I use Sketchup with the Utilities / Query Tool Extension.
    1. Disallow areas in Cura have their Origin at the center of the build plate (regardless of location of the Print Origin)
    2. I draw a Circle with the desired number of sides and diameter in Sketchup at the Origin and then use the Utilities / Query Tool Extension to map out each point on the Circle.
      It generates a specific pattern when building the polygons, which makes it easier and less error prone. In the image below:...
    3. The green highlighted numbers are always Diameter/2
    4. Red arrows show that the Second Point is always replicated to the First Point on the Next Polygon
    5. The Blue arrows show that the First Value of the Second Point is always replicated to the First Value of the Third Point and First Value of the Last Point of the Next Polygon
    6. The Gold and Blue highlighted areas show that halfway through the quarter circle, the Coordinate Points swap (X for Y)
    7. I just build the first Quarter Circle with all Negative Values and then replicate it three times.
    8. I then just alternate the Signs of the X and Y coordinates (-/-, +/+. -/-. +/-) to complete the other three Quarter Circles
    I'm sure there are dozens of different ways of doing this. But this is what I came up with and I find the symmetry makes it easier to build with less errors and typos and easier to detect those errors.
    Enjoy!
    • Like 2
    sorry for the delay. Try this it works for me.
    https://www.dropbox.com/sh/wx43wpt2qi0n5l5/AACDnt1CZPKD9LgK7UB3l4kga?dl=0
    @bobd please post your json file plus instructions for the next person.  Please post it somewhere that it will last for years and not some temporary hosting site like bitbucket.  Maybe you have dropbox?
    • 3 months later...
    Try the new Cura 2.4 beta:
    https://ultimaker.com/en/community/35485-cura-24-beta-is-here
    There's basic support for delta printers (elliptical build plate shape) so you no longer have to create unprintable areas yourself.
    There are probably still issues with this, let us know if it works for you.
      • Ultimaker Transformation Summit
        Visit our virtual showroom and learn more about the Ultimaker ecosystem!
        • 14 replies
      • New here? Register your Ultimaker for free 3D printer onboarding course
