0.1mm Bias
gerycruz
Posted · 0.1mm Bias
Hi everyone, I've been using my Ultimaker 2+ for some designs with tolerances that I thought should be within the printers capabilities.
To test the accuracy of my setup I decided to print a 4x50x10mm box and lay it in different orientations. See attached picture.
Once printed I measured the dimensions with a caliper and always found that they're consistently about 0.1mm larger. Especially in the 4mm dimension.
Any ideas?
I've tried both Cura versions and simplify 3D with similar results. So I'm leaning towards a hardware/firmware problem.
I'm printing with the 0.4mm nozzle using the default Fast settings in Cura using PLA. 5a331df3b063d_ScreenShot2016-06-07at5_53_48PM.png.5bad32acce6e51c9535bd8da5aba8242.png
    Posted · 0.1mm Bias
    You also have to take into account the material expansion/retraction, when it cools the material retracts.
    if it's a bit larger then maybe you are printing to hot causing over-extrusion? What are your print settings?
    Posted (edited) · 0.1mm Bias
    As @DidierKlein mentions, the key here may very well be in your slicer settings.
    Move out of the comfort of the preset profiles and into the advanced and expert domain (these are Cura menus), measure your filament diameter and get to know your printer, then you can and will get closer to your goal :)
